60p editing in FCP?
Ramzi Dreessen
60p editing in FCP?
on Feb 18, 2011 at 5:36:56 pm
I have looked at forums for this already, but they still don't completely answer my question.
I am a journalism student in an art program here at UIUC, and I am working on a short video project, which I want to shoot on a Canon 7D and work with in Final Cut Pro.
I want my final output to be 720p HD at 30fps, but because I want to have the option of having more frames to work with if I want to slow down some of the clips, I want to shoot at 60fps (The 7D can shoot 60p video at 720).
I assume that I'll need to use MPEG Streamclip to convert the H264 files out of the camera to Apple ProRes, which I can then import into FCP to edit. However, what should I do if I want to have the flexibility of speeding up and slowing down clips in the timeline during editing? Do I need to choose the slow-mo clips first, convert those to the correct speed, and then edit everything in 30fps? or can I just work in 60p in the timeline?
I plan on doing test shots on Monday so any responses over the weekend would be helpful. I'm very interested in DSLR shooting because I am planning on purchasing a 7D sometime in the near future, depending on how this goes.
Andrew Rendell
Re: 60p editing in FCP?
on Feb 18, 2011 at 6:03:17 pm
You want to look at this:
http://library.creativecow.net/ross_shane/tapeless-workflow_fcp-7/1
Canon do a plug-in (download from their website) which brings the footage in and converts it to ProRes without you having to convert the files outside of FCP. I've just tried it and it's nice and quick and easy.
Dave LaRonde
on Feb 18, 2011 at 6:13:03 pm
Personally, I'd plan out the shots to be slowed down, and shoot only those at 59.94. Everything else I'd shoot at 29.97. I'd take a lot of time to double-check the frame rates on my shot sheet, because it's worth it later on. To make life easier on myself, I'd shoot at 720, not 1080.
I'd also read this on the recommended way to convert DSLR footage:
Finally, I'd use Cinema Tools to conform the 59.94 clips to 29.97, and edit in 29.97.
The result: a trouble-free edit, courtesy of doing my homework at the beginning of the project.
If I were to choose to blow off the extra effort at the beginning and meticulous double-checking during shooting, I would be punished by nightmare of an edit, a late project, and a lower grade.
Dave LaRonde
Sr. Promotion Producer
Ramzi Dreessen
on Feb 19, 2011 at 12:05:44 am
Thanks! Great response.
Ramzi Dreessen
Photo Editor - Buzz Magazine
Junior, News-Editorial Journalism - University of Illinois at Urbana-Champaign
http://www.rkdphoto.wordpress.com
buzzphoto@readbuzz.com
Ramzi Dreessen
on Feb 19, 2011 at 4:28:57 pm
I do have one question though. Will using Cinema Tools the convert the 59.94 clips to 29.97 change their speed as well (50% speed)? If not, how would I do that? Thanks.
Ramzi Dreessen
Rafael Amador
on Feb 20, 2011 at 1:50:28 am
[Ramzi Dreessen] "I do have one question though. Will using Cinema Tools the convert the 59.94 clips to 29.97 change their speed as well (50% speed)?"
Right.
Is a process that doesn't needs rendering.
just change something on the file-metadata to make it play at 29.97.
DO ALWAIS THIS ON DUPLICATED CLIPS.
This is not undoable.
rafael
http://www.nagavideo.com
