capture
Andrew Zador
capture
on Feb 17, 2011 at 10:39:25 pm
Hello,
I have a problem. I can not capture anything since I performed an OS upgrade. I have tried a lot of different ways to set up the capture preset, but I always get the same message: Unable to initialize capture device. I am using HDV and a MAC OS X 10.6.5. What am I doing wrong? Please help me.
Thank you
Andrew
Chris Tompkins
Re: capture
on Feb 17, 2011 at 11:16:11 pm
did you try an "easy setup" first?
Make sure it matches the format you are capturing from.
Chris Tompkins
Video Atlanta LLC
Zane Barker
Re: capture
on Feb 18, 2011 at 4:06:33 am
[Andrew Zador] "I am using HDV"
Is your camera set do down convert HDV to DV?
[Andrew Zador] "I performed an OS upgrade"
You should know that Pro Apps like FCP can have problems if you simply upgrade a OS or upgrade your version of FCP. It is best to clone your drive, erase it and then start fresh.
**Hindsight is always 1080p**
