Deactivating FX in multiple clips
Sascha Engel
on Feb 16, 2011 at 4:36:56 pm
Hi Everybody,
a Q concerning FX in clips on timeline: I know, how to remove multiple filter in multiple clips at once, by right clicking and choose remove attributes.
How can I do the same operation, but not removing them, but just switching them off?
Thanx.
Sascha
John Pale
Re: Deactivating FX in multiple clips
on Feb 16, 2011 at 4:42:42 pm
No function for that, but how about duplicating the sequence and removing the effects from the duplicate.
Sascha Engel
on Feb 16, 2011 at 5:15:54 pm
Thanx. Yes, I thought about that as well, but if I want to e.g. re-position clips or do other things with them - which are easier & faster when the effects are off, how do I get those adjustments then quickly back to the SEQ where the FX are turned on?
Sascha
David Roth Weiss
on Feb 16, 2011 at 5:38:26 pm
In the RT drop-down over on the left side of your timeline you will see that one option is "play base layer only." Try it...
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
http://www.drwfilms.com
A forum host of Creative COW's Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
Sascha Engel
on Feb 16, 2011 at 6:22:06 pm
Thanx David, but I also know that one.
In my specific case it just didn't help, since I had in the V2 layer a slug Line with Widescreen bars in it, which I did wanna see - to do the right framing.
Just the effects should have been off.
It's those little things that bother me sometimes about FCP workflow - that and a proper masking system and proper audio key frames ;-)
Any idea possiblity to achieve that?
Sascha
Peter Wiggins
on Feb 16, 2011 at 7:37:17 pm
Nothing wrong with the audio keyframes - just use automation
Peter
Sascha Engel
on Feb 16, 2011 at 7:49:38 pm
Very good point - never tried it that way, cause the keyframes put manualkly suck.
By the way - is there any way, I can connect my Oxygen 8 or Akai Midi Controller to connect to FCP?
Sascha
Sascha Engel
on Feb 17, 2011 at 4:04:10 pm
I tried the automation, but it still gives me this hideous curve just before it hits the silence - there's no way to fade down linear in FCP and it's really a pity.
Sascha
John Pale
on Feb 17, 2011 at 6:56:33 pm
[Sascha Engel] "t's those little things that bother me sometimes about FCP workflow - that and a proper masking system and proper audio key frames ;-)"
For motion graphics you have Motion. You can turn things on and off there (and a whole lot more)
For fine audio work you have Soundtrack Pro. (several different types of audio fades exist there)
Final Cut Studio is a suite of programs, and for better or worse, is intended to be used as such. I don't believe any other NLE has what you are looking for either (Maybe Vegas, on the audio issue)
