HD to SD down converting using Compressor - Best Results
jesse wenger
on Feb 16, 2011 at 12:51:18 am
I'm using The Final Cut Pro Compressor to down convert HD to SD for a 30min segment to put on a DVD to give to a local TV station to broadcast. The results have been disappointing. I have been using the trial and error method with no success.
*I go into Compressor and maximize the Mbps settings (under the quality tab) to "Average - 7.6 Mbps" and "Maximum - 8.9 Mbps" (allowing 68 min of footage to be put on one DVD) and I use "two-pass VBS Best".
*I uncheck the box that says "Allow Job Segmenting", because I don't want it.
*(in Frames) Resize Filter is set to "Best".
*Deinterlace is set to "Best".
*Rate Conversion is set to "Best".
*Does "Output Fields" need to be "Same As Source" or "Progressive" or "Bottom First" or "Top First"?
*Should the "Adaptive Details" box be checked?
***What other settings should I place on here so it looks ok? I am still getting some motion blur and its driving me mad.
What else do I need to do to make this look fine? Can anyone help me?
I read this thread: "http://forums.creativecow.net/thread/8/1032896" - it's about down converting, it wasn't much help.
I don't care if my video has to render for 8-24 hrs, time isn't a factor in getting a good quality product here. Should I fully render my video in final cut before I export it to compressor? Or does that not matter at all. I just don't know what else I need to do and I have been spending weeks trying to fix this motion blur issue. Any help would is welcomed, thank you.
Jerry Hofmann
Re: HD to SD down converting using Compressor - Best Results
on Feb 16, 2011 at 4:09:55 am
Why are you deinterlacing it?
What format is the HD? frame rate?
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Paul Jay
on Feb 16, 2011 at 11:13:00 am
What is your SOURCE!!!!!
Normally you want Same as Source.
Just choose a preset.
Change bitrate
Resize filter to best.
Done.
