Final Cut Pro 4 from Newer Version
Brendan Kennedy
on Feb 15, 2011 at 3:05:10 am
Hey i am trying to get Final Cut HD on my computer and i did have Final cut 6 on my CPU and i was trying to get a download for Final Cut 4 HD. Is there any big differences from 6 to 4? I just care about HD quality because i am about to shoot an HD project soon. I just need help please!!!
Scott Sheriff
Re: Final Cut Pro 4 from Newer Version
on Feb 15, 2011 at 4:35:37 am
"Hey i am trying to get Final Cut HD on my computer..."
Uhm, I'm kinda confused here.
What is Final Cut HD?
"...i did have Final cut 6 on my CPU..."
FCP 6 will edit HD
Scott Sheriff
Director
http://www.sstdigitalmedia.com
I have a system, it has stuff in it, and stuff hooked to it. I have a camera, it can record stuff. I read the manuals, and know how to use this stuff and lots of other stuff too.
You should be suitably impressed...
Shane Ross
on Feb 15, 2011 at 6:19:51 am
FCP HD is the name of FCP 4.5. Because it dealt with DVCRO HD natively.
It is not available as a download. You can only look for old copies on ebay or similar.
Why are you trying to run an OLDER version of FCP on your system if you have FCP 6? As Scott said, FCP 6 does HD. Better than FCP HD (FCP 4.5) does.
FCP 6 uses codecs FCP 4.5 doesn't...so there will be a major compatibility issue.
Shane
Scott Sheriff
on Feb 15, 2011 at 6:57:46 am
Shane,
"FCP HD is the name of FCP 4.5. Because it dealt with DVCRO HD natively."
I didn't know that. Wasn't down with FCP back then.
I think I was still doing tape splices on Quad...
Scott Sheriff
Director
Zane Barker
on Feb 15, 2011 at 6:38:17 am
[Brendan Kennedy] "Hey i am trying to get Final Cut HD on my computer and i did have Final cut 6 on my CPU"
Umm why? You already have a MUCH newer and better version of FCP installed why would you need an older version. Projects created with an old version can be opened in the newer version.
[Brendan Kennedy] "i was trying to get a download for Final Cut 4 HD"
Downloading ANY version of FCP would be illegal, but like I said I don't thing you need the older version if you have the newer one.
**Hindsight is always 1080p**
