Log & Capture Mystery!
Gautam Pandey
on Feb 11, 2011 at 6:07:20 am
Hi all,
Have a strange issue at hand...
Footage looks fine in the Log & Capture window, but when I do Captuer now the footage is B&W!
On the timeline however its colour.
Another issue was while capturing the audio would stop and there would be VERY loud static noise almost like a bad cable connection.
However if i stop the capture and refresh FCP the audio is back.
ANy ideas why this might be happening?
Gautam Pandey
http://www.riverbankstudios.com
Shane Ross
Re: Log & Capture Mystery!
on Feb 11, 2011 at 6:19:19 am
What type of deck? How is it connected? What type of footage? Is there a capture card involved?
You're leaving us pretty blind...
Shane
Gautam Pandey
on Feb 11, 2011 at 6:27:28 am
Sorry about that...
FCP version 6.0.6
Deck - Betacam connected through YRB
Footage is SD PAL
Capture Card - AJA Io
Not really an editor myself, so apologising in advance if i seem a little 'thick' about things :)
Gautam Pandey
Shane Ross
on Feb 11, 2011 at 6:36:15 am
Pose that in the AJA IO forum...might get more help...
http://forums.creativecow.net/ajaio
Shane
Gautam Pandey
on Feb 11, 2011 at 6:49:50 am
Thanks Shane.. will give that a shot as well
Gautam Pandey
Paul Jay
on Feb 11, 2011 at 9:56:48 am
In your AJA control panel set analog input to COMPONENT.
Now it's set to Y/C or Composite. That will give you black and white signal.
No mysteries here.
Gautam Pandey
on Feb 11, 2011 at 11:13:39 am
:) Thanks... love it when the world makes sense!
Gautam Pandey
Paul Jay
on Feb 11, 2011 at 11:26:31 am
did it work? Plz mark Solution;)
Gautam Pandey
on Feb 12, 2011 at 4:51:30 am
Hi Paul,
I can't seem to locate the aja control panel! I suspect this might be part of the problem. Though all the setups are available in FCP.
The only AJA folder I found was in a FCS2 Update folder.
Would you recommend i try reinstalling the AJA software?
Gautam Pandey
Paul Jay
on Feb 14, 2011 at 9:23:19 am
It's in your Applications folder.
If not, you haven't installed any AJA drivers
Gautam Pandey
on Feb 14, 2011 at 1:03:24 pm
Yup.. not there..
I'll install the drivers and post the results.
Gautam Pandey
Gautam Pandey
on Feb 16, 2011 at 5:17:12 pm
Hi again!
I installed the drivers which were in a 'Packages' folder, and still no sign of the control panel in the Apps Folder :(
Funny thing is it was working fine and then one fine day it didnt.
The footage is still in colour on the timeline though, so work hasn't stopped.
Gautam Pandey
Tom Bucknall
on Feb 26, 2011 at 5:39:37 pm
The IO Control Panel does not come bundled within the IO drives. The download is available here:
http://www.aja.com/support/io/io.php
Hope this helps.
Gautam Pandey
on Feb 27, 2011 at 3:58:06 am
Thanks Tom! out of town, but i'll download it as soon and update the thread :)
Gautam Pandey
Gautam Pandey
on Mar 3, 2011 at 4:43:07 am
Hi Tom,
I downloaded it.. installed it.. and doubled clicked the icon to launch.
The software crashes and fails to open.
I turned the IO box off, application launches.. but ofcourse says could not detect hardware.
With the app launched if i turn the IO box on.. the app crashes
Any ideas on this?
Gautam Pandey
Rafael Amador
on Feb 27, 2011 at 6:12:45 am
[Gautam Pandey] "The footage is still in colour on the timeline though, so work hasn't stopped."
You have to fallow Paul instructions.
rafael
http://www.nagavideo.com
Gautam Pandey
on Feb 27, 2011 at 6:17:31 am
Thanks Rafael, I did install the drivers again but the control panel never appeared...
Tom posted a link to download the cpanel, will do that and post feedback :)
Gautam Pandey
Gautam Pandey
on Mar 9, 2011 at 5:07:05 am
Followed the instructions..
Any ideas on this?
Gautam Pandey
