JPEG2000 compression
Shane Ross
on Feb 10, 2011 at 9:20:40 pm
OK...I have been asked to deliver a project compressed with the JPEG2000 codec, to play on a projector that is designed to play that back. What software are people using to do this? Does Sorenson 5 do this? Episode?
Shane
Chris Borjis
Re: JPEG2000 compression
on Feb 10, 2011 at 10:03:32 pm
mpeg stream clip should.
John Pale
on Feb 10, 2011 at 10:04:02 pm
Never done it for 'real' (other than the brief test I just did), but you can create a preset in Compressor easily to create a Quicktime file in that codec.
John Heagy
on Feb 10, 2011 at 11:03:01 pm
A search in the Compression Techniques forum may yield some info.
John
Dave LaRonde
on Feb 10, 2011 at 10:44:21 pm
Like John Pale says, Compressor ought to be just fine. So should any compression application that can access Quicktime codecs. I just opened QT 7.4 Pro on the machine at my desk, and there was JPEG 2000, plain as day. You ought to be good to go.
Dave LaRonde
Sr. Promotion Producer
Shane Ross
on Feb 10, 2011 at 11:00:50 pm
Thanks guys...running a test now.
Shane
Walter Soyka
on Feb 11, 2011 at 1:59:30 am
[Shane Ross] "OK...I have been asked to deliver a project compressed with the JPEG2000 codec, to play on a projector that is designed to play that back."
A projector that plays JPEG2000 -- sounds like digital cinema. Are you being asked to supply a DCP package?
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Shane Ross
on Feb 11, 2011 at 2:13:22 am
I was told it was a digital projector, and that I needed to provide a JPEG2000 file...that's all. I'll try to take to the facility to nail this down.
Shane
Joey Burnham
on Feb 11, 2011 at 7:04:38 pm
I think there's a lot more to it than just spitting out a file (maybe, not sure). Every time we have to do this it's for cinema, and I always pass these along to another post house. Usually just send out an HDSR.
Joey
Rafael Amador
on Feb 12, 2011 at 12:53:14 pm
[Walter Soyka] "A projector that plays JPEG2000 -- sounds like digital cinema. ".
Absolutely.
I haven't found any Mac solution for JPEG2000 DCI compliant compression.
Russell wrote about on this article: http://magazine.creativecow.net/article/21st-century-cinema-an-indie-look-a...
rafael
http://www.nagavideo.com
Susanna Moore
on Feb 20, 2014 at 6:37:09 am
Not sure whether Sorenson 5 or Episode can do the job or not.
But the key component to the JPEG2000 standard is the discrete wavelet transformation. It turns out that three discrete wavelet transformations are needed to compress the original image using the JPEG2000 standard.
