How to check duration of a certain part of a sequence?
Joewi Verhoeven
on Feb 8, 2011 at 7:16:35 am
The method I use now is copying the part I want to know the exact duration of, create a new sequence, pasting it in there and then checking the sequence duration. This way however seems a little farfetched to me, I'm sure there's a faster way of checking the exact duration of a selected part of the sequence?
Thanks in advance.
Shane Ross
Re: How to check duration of a certain part of a sequence?
on Feb 8, 2011 at 7:53:00 am
Mark IN, mark OUT...look at the timecode window on the upper left of the Canvas..or the Viewer. That shows you DURATION.
Shane
Joewi Verhoeven
on Feb 8, 2011 at 9:56:44 am
Thanks a lot Shane!
Scott Sheriff
on Feb 9, 2011 at 10:55:53 pm
"The method I use now is copying the part I want to know the exact duration of, create a new sequence, pasting it in there and then checking the sequence duration. This way however seems a little farfetched to me, I'm sure there's a faster way of checking the exact duration of a selected part of the sequence?"
Double face-palm! Have you read the manual?
Scott Sheriff
Director
http://www.sstdigitalmedia.com
I have a system, it has stuff in it, and stuff hooked to it. I have a camera, it can record stuff. I read the manuals, and know how to use this stuff and lots of other stuff too.
You should be suitably impressed...
