Export via QT Conversion to WMV exports only first 29 seconds(?)
Maxwell Federman
on Feb 7, 2011 at 5:53:56 pm
Hello--
I made the mistake of telling a client it would not be a problem converting his material to WMV.
I captured his tapes using DV; and figured it would be no problem to export them using the Quicktime Conversion export dialog.
I exported a short test file (8 seconds) and emailed it to a friend with a windows computer to test quality and compatibility.
The test went fine, but now I am trying to export the full files and it is only exporting the first 29 seconds. Plus the quality appears to have taken a hit. I'm gonna keep trying to adjust these settings and maybe will see if MP4 files would be ok (?)
Your advice is appreciated; thanks for reading this!
Dave LaRonde
Re: Export via QT Conversion to WMV exports only first 29 seconds(?)
on Feb 7, 2011 at 5:56:51 pm
Got the freebie version of Flip4Mac, which only lets you convert a limited duration of footage?
Open your wallet and pay for the full version, and that problem goes away.
Dave LaRonde
Sr. Promotion Producer
Thomas Morter-Laing
on Feb 7, 2011 at 7:36:00 pm
If your client has QuickTime or can install it, do h264. Free and better :)
:D
Tom Morter-Laing
Freelance Editor
Certified Apple Product Proffessional, 2010
http://www.depictproductions.co.uk
Sony Z5, with Rode NTG2.
iMac 27" intel i7 2.93GHz, 12GB RAM, ATI HD5750 [1GB GDDR5], 2TB Int. SATA with 2TB External HDD; (FW800), with Elgato Turbo H264HD.
