HDMI external monitor, video drops frames and audio delay
Luciana Jauffred
on Feb 4, 2011 at 4:57:06 pm
Hello, I'm using an HD LED TV as an external monitor, conected via minidvi/HDMI. I'm trying to playback Appleprores 422 HQ files, but the video drops frames and stutters and the audio is delayed. In the past I solved this issue easily changing the Playback Video Quality to medium in the timeline, but this time the trick won't work. I'm wondering if this is because I'm using a new LED TV or if this is a cable issue.
I need this monitor to be external, don't want to use the mirror monitor option. Any help would be appreciated, thanks.
Shane Ross
Re: HDMI external monitor, video drops frames and audio delay
on Feb 4, 2011 at 9:41:17 pm
Computer? Graphics card? This is all dependent on your graphics card, as it is the one managing the playback. If you have a base stock card, it might not be up to the task.
Shane
