1080p 25 conversion to NTSC
Rick DeSalvo
on Feb 3, 2011 at 2:26:33 pm
Got some footage back from a client who was in Spain. She asked for NTSC and got 1080p 25. Does anyone know of an inexpensive piece of software that will convert ProRes 422 PAL to NTSC? It's going to NTSC DVD eventually and I'll need to convert it. Not sure if DVD Studio Pro can accomplish this. Thanks.
Shane Ross
Re: 1080p 25 conversion to NTSC
on Feb 3, 2011 at 2:42:25 pm
Compressor.
Shane
Rick DeSalvo
on Feb 3, 2011 at 2:51:42 pm
Thanks...any idea which codec works best? DV NTSC? SD Uncompressed 10-bit? The program contains PPT JPEGs and the expectation is that these images need to be maintained.
Shane Ross
on Feb 3, 2011 at 2:55:17 pm
Why are you listing SD codecs when your footage is HD? Is the rest of your footage SD?
DV is the LAST choice to convert to. THe worse format of SD out there. ProRes NTSC, or DV50 (DVCPRO 50), or Uncompressed 10-bit...but only if your drives can handle that speed.
Shane
