Importing footage with Alpha channels
Sascha Engel
on Jan 28, 2011 at 1:51:58 pm
I seem to fall over that problems again and again: When I import footage, which I worked on in AE - e.g. created a Mask inside footage and exported it from AE with Animation Codec including the Alpha Channel - I do not seem to be able to make FCP understand and see that part to make it transparent.
Same thing for PS - when I worked on some titles - exporting it with transparent background - FCP makes it opaque and does not recognize its transparecy. Even when I set the layer's composite mode to Alpha Channel.
Thanx for advice.
Sascha
Tom Wolsky
Re: Importing footage with Alpha channels
on Jan 28, 2011 at 2:44:49 pm
Are the Adobe products on a Mac or PC?
After you import go to the alpha column in the browser and set the alpha channel. You did output from AE with colors set to millions+?
All the best,
Tom
Class on Demand DVDs "Complete Training for FCP7," "Basic Training for FCS" and "Final Cut Express Made Easy"
Author: "Final Cut Pro 5 Editing Essentials" and "Final Cut Express 4 Editing Workshop"
Sascha Engel
on Jan 28, 2011 at 3:46:03 pm
Yes, the AE is also in my MAC. I managed to fix it with setting the Alpha Channel in the Browser Tab.
I still struggle though sometimes with Still coming from PhotoShop - it doesn't wanna recognize the A-Channel there. Specially, when I create something that is supposed to work as an A-Channel Mask.
Sascha
