workflow from Jpeg 2000 time line to SD DVD
george sloan
on Jan 26, 2011 at 8:42:28 pm
Please advise me as to the best Quality workflow beginning with an important 30 minute project that has been shot and edited in 1O80i ...then rendered (with compression markers)to JPEG2000 or JPEG Photo.
I have exported to quicktime conversion and the movie looks great but here this problem..
When compressing to DVD SD 4:3 either directly to compressor or QT then compressor. I am getting less than desirable results in terms of picture/color quality when played back as a dvd. (the 16:9 letter boxing and aspect ratio is perfect)...Need advice on workflow/settings starting with the Jpeg timeline.
Thanks George Sloan sloanmotion.com
using---FCP 7
Model Name: Mac Pro
Model Identifier: MacPro1,1
Processor Name: Dual-Core Intel Xeon
Processor Speed: 2.66 GHz
Hector berrebi
Re: workflow from Jpeg 2000 time line to SD DVD
on Jan 26, 2011 at 8:58:59 pm
hi George
can you describe "less than desirable" what are you seeing in the DVD that looks wrong?
also, what was it shot on?
and why the jpeg 2000 conversion? was it done by sequence settings?
...dvd's tend to generally look less than desirable when compared to their HD source
hector
Hector Berrebi
Schibber Group
prePost Consulting
george sloan
on Jan 26, 2011 at 9:54:08 pm
Thanks Hector
less desirable means means that i would like to produce better quality image for final input
to sd dvd...will use for for dvd distribution and local broadcast...but don't let deter you from
original question.. i use JPEG 2000 because I love it.
Question is about workfow/settings see recent previous post
George
Hector berrebi
on Jan 27, 2011 at 6:33:19 am
[george sloan] " i use JPEG 2000 because I love it."
love makes people do all sorts of irrational things :)
i would recommend the following workflow
i believe you captured via FW to HDV files.
next time
capture to Prores HQ (you have a preset for that, HDV - Prores, in the audio video settings
use a Prores sequence setting
export quicktime movie using current settings - do not recompress all frames
in compressor, do what Rafael recommended in his reply
test this out for a short segment, and compare it to what you got previously
hope this helps
hector
Hector Berrebi
Schibber Group
prePost Consulting
george sloan
on Jan 27, 2011 at 7:08:04 pm
Thanks Hector,
You and Rafael are good people!
Hector berrebi
on Jan 27, 2011 at 8:22:21 pm
YW
happy i could help
Hector Berrebi
Schibber Group
prePost Consulting
george sloan
on Jan 26, 2011 at 10:26:32 pm
Thanks Hector
Sorry about multiple posts but my first post. yesterday which was comprehensive is yet to be answered.
To further answer your questions it was shot in a cannon xh a1 in 1O80i thus the 1080i timeline.
Switched to Jpeg2000 in sequence settings and rendered full for 4 hours...now jerky in canvas.
George
Rafael Amador
on Jan 26, 2011 at 10:37:08 pm
- Avoid QT Conversion like the pest. No control on any process.
- In Compressor set "Frame Control ON" and "Resize Filter" BEST or BETTER
rafael
http://www.nagavideo.com
Paul Jay
on Jan 27, 2011 at 5:40:41 pm
Rafael,
I see you adapted my Compressor downscale advice
Which wasn't really good in your opinion right?
I have to say, the FCP downscale solution is nice too, but not as good as Compressor Resize filter;)
Rafael Amador
on Jan 27, 2011 at 7:32:44 pm
Hi Paul,
Setting the "Frame Control ON" is not critical just because its allows to chose different filter "qualities", but because allows Compressor works in 32b Floating Point (up to the Compressor manual).
However, I have to say that, personally, I don't think that FC (when set to High Precision and Motion Effects: BEST) makes a worst job than Compressor. In fact I doubt very much if is worth the pain of going to Compressor instead of downscaling in FC. I think that probably both use the same engine.
Last year I made some serious (?) downscaling tests with all the applications I had available:
- Compressor
- Purifier
- SHAKE.
Since then, I only use SHAKE for any downscaling. The difference with the other applications is indescribable.
Cheers,
rafael
Paul Jay
on Jan 27, 2011 at 9:52:02 pm
Hm interesting. I will to some tests with Shake then.
Compressor is nicer when you use a Cluster ( Qmaster settings )
This way you can use all the cores in your MacPro in Compressor.
Cheers.
Rafael Amador
on Jan 27, 2011 at 10:53:12 pm
Hi Paul,
Same than Compressor, SHAKE use Qmaster for job distribution, so you can put all your cores to work; but the best is that you have different filters for the kind of job (Up/downscaling) and for different kind of stuff (video, Graphics).
For Downscaling I use the "Dirac" filter.
BTW, Motion has a very good filter (also present in SHAKE) for downscaling: Lanczos.
Is in the "Image Units".
However Motion doesn't render in Floating Point.
rafael
george sloan
on Jan 28, 2011 at 12:02:06 am
Hi Again Rafael,
I am now converted officially to ProRES.
Its all good except for render times. I do need help on render times. Last night i did 2 tests. Both exporting directly from timeline to compressor.
One used QT settings the other Mpeg2 settings. The mpeg 2 worked well the qt settings did not.
Plus the Mpeg2 was 1 hundred times faster compression.
Today I am testing a 3rd method...MPEG (no conversion as instructed) to compressor where I used the
Mpeg settings that worked so well last night. The render time is horrendous! So I guess I'll go
back to the strait to compressor method.
Any comments? Thanks again.
George
sloanmotion.com
