FCP exporting movie and related files
Tarina Reed
on Jan 25, 2011 at 7:29:40 pm
Hello,
I'm a using FCP to edit my reel. I want to add footage from a feature I DPed. Instead of downloaded every single clip to a hard drive, I was wondering if there is a way to take a movie file then relate it to the original clips in the sequence. That way I am only downloading the good takes and reducing the amount of time spent going through every clip. I also want to make sure I get the original clip so I have the highest resolution to work from.
Any advice would be greatly appreciated.
Regards,
Tarina
Rafael Amador
Re: FCP exporting movie and related files
on Jan 25, 2011 at 8:35:28 pm
You can use QT to make a preselection of the stuff from your feature.
Open the movie with QT Player (Pro needed) and set IN and OUt points. Copy and paste the selections to a new window. When finished you can "Save.." your movie as a Reference or Self-contained.
rafael
http://www.nagavideo.com
Olin Padilla
on Jan 25, 2011 at 9:26:17 pm
Try using the media manager. There should be a way to transfer only the used footage (with handles).
Personally, I would keep all the footage together, since you never know how you're going to want to re-edit your reel in the future.
