Audio loosing Sync
Elliott Dunwody
Audio loosing Sync
on Jan 25, 2011 at 7:21:59 pm
Hi guys,
Ever since I upgraded to Studio 7 my audio wants to loose sync. Any fixes?
Bright Blue Sky Productions
4811 Rivoli Dr
Macon, GA 31210
http://www.brightbluesky.com
Elliott Dunwody
Re: Audio loosing Sync
on Jan 25, 2011 at 7:30:12 pm
I guess I need to say audio drift instead of loosing sync
4811 Rivoli Dr
Macon, GA 31210
Olin Padilla
on Jan 25, 2011 at 7:48:59 pm
More info needed.
If you open an FCP6 project in FCP7 does the audio drift? If not, then does the same footage drift in a new project?
Also, have you installed the updates?
Elliott Dunwody
on Jan 25, 2011 at 8:17:20 pm
Right now the drift is with new projects started in 7. Will check to see if there are any updates available.
Editor is in session right now. Thank you.
E
4811 Rivoli Dr
Macon, GA 31210
