Bit Rate
Jola jones
Bit Rate
on Jan 24, 2011 at 4:59:51 pm
First I would like to apologize for not being technologically savy.
I am sending a file to a cable station and this is what they said about the file I sent
"The data rate is just below our minimum, 5.8 and needs to be 6 Mb"
How do I adjust this? Can I adjust this? I am working in FCP 5.
Thank You!
Rafael Amador
Re: Bit Rate
on Jan 24, 2011 at 5:03:07 pm
That will depend of the kind of file you are sending, and the application you are using to compress the file.
rafael
http://www.nagavideo.com
Jola jones
Re: Bit Rate
on Jan 24, 2011 at 5:04:50 pm
I was exporting it using FCP and making it a .mov file.
Jola jones
Re: Bit Rate
on Jan 24, 2011 at 5:21:41 pm
Think I got it to work.
Rafael Amador
Re: Bit Rate
on Jan 24, 2011 at 6:23:22 pm
If you don't say which codec and setting are you using, all is a guess.
rafael
