Batch export data rate setting
John Simpson
on Jan 21, 2011 at 5:38:35 am
Hello,
I am making a bunch of sub clips to export to QT movies, that will then be used as reference for creating animation in flash. Since there are so many I want to make them then do one batch export. But in batch export settings there is no way to set data rate to "Automatic" like I would normally do with an export. Is there a way? If I randomly pick a number are there consequences to playback, specifically frame rate.
Any help would be appreciated,
JS
Jerry Hofmann
Re: Batch export data rate setting
on Jan 23, 2011 at 2:34:09 pm
Your question is unclear. If they are just reference movies and you don't change the frame rate, where's the problem?
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
