Coloring correcting two camera's exposure's difference...?
Grant Wilber
on Jan 19, 2011 at 11:50:35 pm
I shot a segment with a 2nd camera man. We both had T2i's. Used the 18 - 55 stock lens. white balanced on the same card. Same ISO (1600). And double checked cameras settings and everything looked the exact same.
The images I got back where completely different.
I was at shooting on mostly 55mm / 5.6 and he was opened at a closer to the 18mm end which opens more to 4 the whole time. But still I feel like some shots are similar focal lengths but still different images. also the wider camera is so much sharper. Is this a lens or camera defect? Or is that lens just a lot sharper when open more. anyone know whats goin on or how to correct it? Here are some screen shots of the original footage.
Cam A (35mm ish)
http://img20.imageshack.us/i/screenshot20110105at105.png/
Cam B (35mm ish)
http://img801.imageshack.us/i/screenshot20110105at105.png/
Cam A (18mm ish)
http://img232.imageshack.us/i/screenshot20110110at942.png/
Cam B (18mm ish)
http://img200.imageshack.us/i/screenshot20110110at941.png/
This is my attempt to correct the footage:
Any other pointers or tips to get this footage looking the same-ish. Thanks.
Shane Ross
Re: Coloring correcting two camera's exposure's difference...?
on Jan 20, 2011 at 12:06:07 am
Same ISO...but apparently not the same F-stop.
Shane
Grant Wilber
on Jan 20, 2011 at 12:30:09 am
I figured it was a f-stop difference. Although I couldn't believe how much more sharper and contrasty the overexposed camera was.
any ideas for fixing this in FCP?
Shane Ross
on Jan 20, 2011 at 12:45:54 am
Color correction is something that is very tough to tell someone how do to via a forum. You have to adjust the exposure...well, the lows and mids and highlights until you find the happy medium. I'd tackle this in Color, as I can push things more, and have more fine tuning control. FCP's 3 way, and brightness and Contrast filters are iffy.
Just gotta play with it, or hire a colorist.
Shane
