g5 with new memory added still gets out of memory error
steev brown
on Jan 19, 2011 at 7:44:12 pm
My FCP was telling me out of memory when trying to render. I have dealt with this in the past with all trix suggested, and i have been able to manage getting past it until now. I broke down and bought additional RAM. When I went to add the new I found each slot was already full. After reading what to do in this situation, I swapped out the inner most 2 matching pairs that had the largest chips. And now I still get the same error.
I have 4g avail RAM
and plenty of HD space
It's not a huge project just a bit of compositing.k
thanks
Patrice Freymond
Re: g5 with new memory added still gets out of memory error
on Jan 19, 2011 at 10:05:38 pm
More details about hardware and the nature of yur fcp project would help in helping you...
Patrice
Steve Weslak
on Jan 20, 2011 at 4:54:58 pm
I've gotten "out of memory" errors when working with still photos that have a pixel count of more than 4,000 on any side of the image. I learned that FCP will only handle photos up to that size. Rescaling the photo to a smaller size has always cleared up the problem.
Paul Jay
on Jan 31, 2011 at 11:04:10 am
If you want to edit with 4K photo's.
Don't use FCP. This is normal behaviour.
Use After effects or Motion.
Rafael Amador
on Jan 31, 2011 at 4:00:51 pm
[Paul Jay] "If you want to edit with 4K photo's.
Use After effects or Motion."
That's right.
If you want to do it in FC, reduce the size, and better if you avoid JPEGs.
rafael
http://www.nagavideo.com
