Dolby E layoff nightmare
Thom Obarski
on Jan 18, 2011 at 2:36:55 am
I need to layoff a couple of spots with stereo and dolby E to HDCam; however when I go to capture the project post layoff (just to test to see if everything is working ok) i'm getting super stuttery audio thru the decoder and crc errors on almost every frame; any thoughts? We're doing a cross conversion thru an FS-1 from 23.98 to 59.94; I had the sample rate conversion off; and just to make sure I retested the audio by doing an audio only insert directly from a 29.97 timeline.
everything seems ok with fcp settings if i play directly from the timeline thru the decoder I get perfect audio; its just the recaptured audio that is stuttery; unfortunately since it's a software solution i can't find any way to monitor during capture; so there's always the option that I'm distorting it somehow on recapture and it's actually fine on the tape.
Setup
our inhouse deck is the HDW-1800; I have it set so that the audio is recording burst data to tracks 3&4 audio is set to cut & 1f (I read somewhere having your ref set to SD for external would help; but my ref is set to video in; so really the hd/sd distinction there shouldn't matter right?)
fcp 7.0.3 with track assignment 4 mono tracks;( recapture settings: Aja 10 bit; proresHQ 1080i29.97 48/24 audio)
kona 3v8.0
Any and all help would be much appreciated!
~Thom
"This is post, you can't fix it after this."
Thom Obarski
Re: Dolby E layoff nightmare
on Jan 18, 2011 at 3:04:18 am
***UPDATE***
Found a way to wire the deck thru the system so the decoder could read the tape directly w/o re-capture and it's def not getting onto the tape correctly; any pointers at this point would be greatly appreciated.
David Penfold
on Jan 18, 2011 at 1:39:47 pm
Some Sony HD Tape decks are very strict on accepting a non referenced video signal. When you are laying off the material - what is the channel condition of the deck? You could try timing the output of the FCP in to the deck???
Thom Obarski
on Jan 21, 2011 at 8:45:15 pm
I switched to an sd ref from blackburst and that worked for a 30 seconds spot that we were doing; now today I'm trying to lay off the full feature and am again getting stuttering, even with the same settings as when we did the promo; makes me want to pull my hair out.
Thom Obarski
on Jan 21, 2011 at 11:50:06 pm
Also looks like some sort of timecode thing going on; monitoring from my timeline it reads the file as DF and timecode matches timeline timecode perfectlly; then i write to tape which is also setup as DF; but monitoring off of there the decoder is reading the timecode data as still DF but is a little off; kinda hard to tell since TC data goes away in the decoder if you don't have an active stream, don't know if it's the delay processing from the tape; also getting pure silence now.
