Can't change size of timecode reader
Annu Lilja
on Jan 16, 2011 at 6:39:30 pm
I need to put a timecode on the project I am exporting to QT. I am nesting my sequence and adding timecode reader on it. The timecode is correct, but I want to remove the black box, and I want the timecode to be smaller. When I go to the filters tab to make the changes, nothing happens. What could be the problem? If I add the filter onto a slug, I am able to adjust the size of the timecode. Does this problem have something to do with nesting? Is there another way I can add the timecode on there? My project is 80 mins long. FCP 6.0.4, Macbook pro.
Thanks for your help.
Jeremy Garchow
Re: Can't change size of timecode reader
on Jan 17, 2011 at 2:47:02 am
Are you loading the nest in to the viewer and adjusting the filter there?
