multiple clip formate
Ashish Sah
on Jan 13, 2011 at 2:56:09 am
i m editing a film which is shoot in diff cam pd-170(720*576 25fps)and sony hdv z1(1440*1080 25fps)..
now after editing i hav to tranfer total film for digital cinema..
they accept only 1920*1080 (24fps).
whenevr i change my clips dimensions its totaly prixlet and frm doesnt look good..
how can i upgrade its quality...
Daniel Ludwig
Re: multiple clip formate
on Jan 13, 2011 at 3:42:36 am
I would upscal your SD-material using innobits purifier, but you need to know that HDV native resolution is 1440x1080.
so I would upscale your HDV-material to 1920x1080 using purifier as well - maybe I would use the pro-res codec.
then you need to do a frame-rate-conversion to 23.98p. this is quite a bit complex, but I wrote a small tutorial for this.
it´s been another context, but the workflow is the same.
to use apples Cinema Tools is a common workflow for things like this.
hope this helps
© 2018 All Rights Reserved
