FCP Export/Quicktime Conversion/WAV (or anything) Shortcut?
Mike Sutton
on Jan 11, 2011 at 11:17:06 pm
I'm using FCP 5 (for now) and have recently begun to mess with custom hot keys. I've been able to add "Export Using QuickTime Conversion" as one, but am still having to manually select the format. I'm wondering if anyone knows of a way to make a hot key for a specific format under the "QuickTime Conversion" option (I'm personally trying to make it WAV).
Thanks in advance!
Jeremy Garchow
Re: FCP Export/Quicktime Conversion/WAV (or anything) Shortcut?
on Jan 12, 2011 at 2:25:27 am
Unfortunately no, but you can set one for aiff.
