storing avchd
Steve Tamou
storing avchd
on Jan 6, 2011 at 3:49:09 am
Since AVCHD is not native to FCP, It takes up a lot of space to store the media on the hard drive. Is there another way of storing this file with out taking up as much space?
Steve Eisen
Re: storing avchd
on Jan 6, 2011 at 3:51:58 am
Make a disk image of your SD card.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
Shane Ross
Re: storing avchd
on Jan 6, 2011 at 4:21:09 am
Get another hard drive. You should not be storing the AVCHD masters on the same drive as your converted media. They should be on separate drives. If the drive died, then EVERYTHING is gone.
Two sets of drives...archive drives and media drives. Archive drives can be cheaper, as in not as fast, and not needing high speed connections. USB works fine.
Shane
Kent Stipp
Re: storing avchd
on Jan 6, 2011 at 5:01:23 am
I couldn't agree with Steve and Shane more.
Personally with my AVCHD I keep the original SD card, I never re use them they are
so cost friendly and then I have a Hard drive dedicated to Backups of my SD cards. My Media Raid is then for stock or current media projects.
Kent Stipp
Life Begins at 155mph
Ki PRO Lens to Post
3am Studios llc.
3amstudios.org
Sharedsummitsfever.com
