Skipping Frames?
Chris Kronenberger
Skipping Frames?
on Jan 6, 2011 at 1:33:28 am
I'm trippin, And I am sure the answer is right in front of my face... So at the expense of showing my ignorance;
I shot 1080/30p footage of a school production, in HD,,, with a shutter speed of 1/15. (low light) I did a "Log and Capture" into FC Pro as I have 100 times before, and my footage in the viewer and on the canvas, both look like I'm skipping frames! (jerky) and I cannot find a setting to modify that
Re-shot some footage at different settings to see if that would remedy the situation and I am still getting the same effect.
Anybody know what I am overlooking?
Shane Ross
Re: Skipping Frames?
on Jan 6, 2011 at 2:23:48 am
Play the footage frame by frame. Are the frames repeating?
Shane
Chris Kronenberger
on Jan 6, 2011 at 2:27:20 am
Thanks for the reply.
No, they are not repeating.
FYI: I just imported some footage from one of the other cameras in the building and it is doing the same thing.
Chris Kronenberger
on Jan 6, 2011 at 2:34:39 am
Wow,,,, I found the problem.
System Settings, "Playback Control" tab, "Frame Rate" (was set to 1/4 frame)
How that happened, I do not know,,, but I'm back in business.
Again, thank you for taking time to write.
C.
