mpeg2@main level export from final cut pro
ryan early
on Jan 1, 2011 at 4:06:27 am
I have to deliver a program to a television network and they have given me these specs. Compressor doesn't allow me to export mpeg2 with 422 chroma. Not sure the best way to go.
Stream Mpeg Programmme Stream
Video Compression Mpeg 2 4:2:2 Profile @ Main Level
Video Bitrate 10-15 Mbps (15Mbps VBR preferred)
Video Resolution 720x576i
Video Frame rate 25fps
Video Aspect Ratio 16:9
GOP structure Long Maximum GOP length 15
Number of channels 2 stereo (CH 1 / CH 2)
Audio Sample rate 48Khz
Audio Bit Depth 16 bits
Rafael Amador
Re: mpeg2@main level export from final cut pro
on Jan 1, 2011 at 11:03:47 am
[ryan early] "Video Compression Mpeg 2 4:2:2 Profile @ Main Level"
FC handle this only when exporting IMX or XDCAM HD 422.
However those are "locked-formats" so you can not tweak data-rate, GOPs structure, etc.
I think you need a more pro tool like Episode or so.
rafael
http://www.nagavideo.com
Alan Okey
on Jan 1, 2011 at 7:22:17 pm
[ryan early] "Compressor doesn't allow me to export mpeg2 with 422 chroma."
Up until recently I thought the same thing, but Jeremy Garchow posted this:
http://forums.creativecow.net/readpost/8/1112801
Rafael Amador
on Jan 1, 2011 at 10:27:29 pm
Great info alan.
I have to refresh my knowledge.
rafael
ryan early
on Jan 2, 2011 at 3:13:24 am
I saw that post too, it must only be in the latest version of compressor - I have compressor 3.0.5 which doesn't have that option for 422 export of mpeg2.
Jeremy Garchow
on Jan 2, 2011 at 5:16:07 am
Yes, it came in Compressor 3.5 and FCS3.
ryan early
on Jan 2, 2011 at 8:41:18 am
Thanks for the replies, looks like I am off to a post facility then ! Don't want to buy the new fcs at the moment with the new fcs not far away.
Jeremy Garchow
on Jan 2, 2011 at 5:27:06 pm
Episode will do it as well.
Craig RussillRoy
on Jan 2, 2011 at 7:50:09 pm
Hi Guys,
Only Episode and Adobe Media Encoder are the best on the MAC PLATFORM for 4:2:2 Chroma ...
10-15 VBR in Long GOP seems quiet small for TV Delivery, as is is PAL and England normally accepts only 50 iFrame 4:2:2 I know no UK Broadcaster would accept 10-15 Mbps at 4:2:2 ...
Hope this helps try Adobe Media Encoder
Adstream
London, England
Mac Pro - 8gig ram - FCS 3 - CS4 - Cinema 4D, Flip Factory, Rhozet, Episode
Rafael Amador
on Jan 3, 2011 at 1:14:57 am
[Craig RussillRoy] "10-15 VBR in Long GOP seems quiet small for TV Delivery, as is is PAL and England normally accepts only 50 iFrame 4:2:2 I know no UK Broadcaster would accept 10-15 Mbps at 4:2:2 ..."
I think 15Mbps for SD delivery is really good data-rate.
That should yield similar quality than XDCAM HD 422 50Mbps.
Rafael
