Twixtor issue
Guiri Reyes
Twixtor issue
on Dec 24, 2010 at 2:40:10 am
i have use twixtor before...
it was working properly on my final cut 7....
just now started to show like this http://img140.imageshack.us/i/screenshot20101223at930.png/
-even after render.
tryed to uninstall , but wasn not able to do it, found the folder that have to be deleted and everything...
tryed to install twixtor 5 btu it didnt even show up on FCP.
does any one knows these symptoms ?
http://vimeo.com/grreyes
Rafael Amador
Re: Twixtor issue
on Dec 24, 2010 at 11:22:37 am
That looks like the plugin is not properly installed.
[Guiri Reyes] "tryed to uninstall , but wasn not able to do it, found the folder that have to be deleted and everything...
tryed to install twixtor 5 btu it didnt even show up on FCP."
Go to Main/Library/Applications Support/ Final Cut Pro Support/ Plugins.
Delete the plugin from there.
You may need to delete the Twixtor Preferences as well: Main/ Library/ Preferences/ REVIsion Effects/ Twixtor.
Also you may need to delete the REVision folder on the Applications, if any.
rafael
http://www.nagavideo.com
