1080i scenes reverse telecine'd won't render?
Tom Matthies
on Dec 12, 2010 at 3:32:43 am
I shot footage with my HVX200 as 1080 at 24P. Since the files are actually 1080p over 60 and have interlacing, I ran the them through Cinema Tools and reverse telecine'd them, removing the pulldown and converting them to 23.98 for editing. All works well during the edit process with no pull down issues. This was all green screen compositing so interlacing would not be good.
When it came time to render, it wouldn't. Instead I got this error message: "Codec not found. You may be using a compression type without the corresponding hardware card."
The original footage is DVCProHD. I'm editing in a 1920x1080 ProRes 422 seqence. The converted files, when played in Quicktime indicate that they are still in the DVCPro HD format. The original files with pulldown work fine and render. The files with pulldown removed won't render at all. Any ideas?
Tom
E=MC2+/-2db
