avi files
Ryeal Simms
avi files
on Dec 9, 2010 at 6:03:50 pm
I'm using a DVX-AG-100A, When I download my footage to Final Cut Pro Studio my files come in as AVI FILES, HOW DO I STOP THIS?
Dave LaRonde
Re: avi files
on Dec 9, 2010 at 6:34:05 pm
Use the proper Easy Setup in FCP for your camera.
Browse through the available ones in FCP, scrutinize them & choose the one that allows you to capture DV via firewire. There should be ones for both NTSC and PAL DV.
Dave LaRonde
Sr. Promotion Producer
Michael Gissing
Re: avi files
on Dec 9, 2010 at 9:49:33 pm
You don't say how you are 'downloading'. If you are using log and transfer in Final Cut, then you will create quicktime files,not AVI. Check the manual for the procedure to connect a DV camera to FCP. It sounds like you are using a PC to capture the files which is wrong.
