Project on an external hard drive - moving to different machine problem
Brian Evancic
on Dec 9, 2010 at 5:55:20 pm
I have a fcp project with multiple clips with difference aspect ratios. I have it on a external hard drive with the capture scratch dedicated to the project folder. When I move the hard drive to a different machine (with the capture scratch set correctly to the original location) it wants me to render all the clips but I haven't done anything to them yet. Any suggestions?
jack Bibbo
Re: Project on an external hard drive - moving to different machine problem
on Dec 9, 2010 at 6:24:31 pm
Are the machines equal in configurations? Speed? Card? Etc
Brian Evancic
on Dec 9, 2010 at 6:38:08 pm
The first machine is a iMac Core 2 Duo with 16GB RAM and the other is a Powerbook laptop with 4GB Ram. Would this make a difference?
jack Bibbo
on Dec 9, 2010 at 7:14:10 pm
Well yes.
The Intel machine (Core Duo) is going to be faster and will effect render times as well if you need to render at all.
Hope that helps.
