Changin Bit Rate on an Apple Pro Res HQ Export? Possible?
Ryan Foregger
on Dec 7, 2010 at 5:48:15 pm
Hi all,
I got a deliverable request from a client in Argentina that has me scratching my head. They want Quicktime with the following specs.
Container: .mov
Codec: Apple ProRes 422 (HQ)
Raster: 1920x1080px
Pixel Aspect : Square
Colors: Millions
FPS: Source
Field Order: Lower
Data Rate: 60Mbps
Using Quicktime Conversion out of FCP7 or Compressor, I don't see an option to change the bit rate. It's grayed out. I assume because ProRes HQ codec requires a certain automatic bit rate.
Is it possible for me to make a file to their specs?
If so, how?
Thanks in advance
John Pale
Re: Changin Bit Rate on an Apple Pro Res HQ Export? Possible?
on Dec 7, 2010 at 6:21:46 pm
Nope.
The bit rate is hard wired into the codec.
Also 1080i HD is UPPER Field first.
Ryan Foregger
on Dec 7, 2010 at 6:51:54 pm
I noticed that about the lower field request. Interesting thing about that, my source file has field dominance at none, and I was able to change it to lower in the sequence without "seeing" any change. But the whole thing seems screwy nonetheless.
So, 1 vote for not possible...
