followup
Lonnie Goodwin
followup
on Dec 4, 2010 at 11:01:21 pm
Hello--
To clarify: this problem is not apparent in FCP itself, but in my QT export. The posts I read on the subject said a possible solution was to use the native codec. However, I need to use a specific codec for the purposes of this project. So is there another solution?
Lonnie
Rafael Amador
Re: followup
on Dec 4, 2010 at 11:31:34 pm
Hi Lonnie,
[Lonnie Goodwin] " The posts I read on the subject said a possible solution was to use the native codec."
Which suggest?
Solution for which problem?
[Lonnie Goodwin] " itself, but in my QT export. The posts I read on the subject said a possible solution was to use the native codec. However, I need to use a specific codec for the purposes of this project."
Which specific codec do you need?
Please a bit of info. like that is impossible to try to help you.
rafael
http://www.nagavideo.com
Jeremy Garchow
Re: followup
on Dec 4, 2010 at 11:36:43 pm
If you started a post somewhere else, you should add to that post.
