Uncompressed 8 bit 4:2:2 to mpeg 2 (720x486)
Chase Maser
on Dec 2, 2010 at 4:19:28 pm
One of are half hour tv shows was picked up by another distributor. We would usually just send them a beta tape with the episode, but they wanted the show as an mpeg2 file. Whenever I use compressor it always turns the frame size from 720x486 to 720x480. Is there any way to keep the original frame size with an mpeg2?
Chase Maser
Editor
http://www.he-tv.com
Jeremy Garchow
Re: Uncompressed 8 bit 4:2:2 to mpeg 2 (720x486)
on Dec 2, 2010 at 4:23:27 pm
Is that what they requested? You should make sure that they want a DVD compliant stream and not a program or transport stream with muxed audio.
Alan Okey
on Dec 2, 2010 at 5:12:56 pm
[Jeremy Garchow] "You should make sure that they want a DVD compliant stream and not a program or transport stream with muxed audio."
And if they do want a transport stream, get the exact specs. If it has to be 4:2:2 MPEG-2 (which Compressor cannot produce), you'll need to use something like Telestream Episode. Others have run into this issue when trying to encode content to DG Fastchannel's specs.
Jeremy Garchow
on Dec 2, 2010 at 5:19:45 pm
[Alan Okey] "And if they do want a transport stream, get the exact specs. If it has to be 4:2:2 MPEG-2 (which Compressor cannot produce)"
Actually, you can these days believe it or not:
Still Chase, you need to check with the recipient as you have to figure out if there needs to blanking, and perhaps they want something like an IMX50 file.
Jeremy
Rafael Amador
on Jan 1, 2011 at 8:43:44 pm
[Jeremy Garchow] "Actually, you can these days believe it or not:"
I believe it :-)
I've to update my self about Compressor.
Thanks for the info.
rafael
http://www.nagavideo.com
Alexander Kallas
on Jan 1, 2011 at 9:05:54 pm
[Jeremy Garchow] "
However if you look at your screen-shot, it says
"YUV 4:2:2 Color encoding (not for DVD use)
So why use MPEG2?
Cheers
Alexander
Jeremy Garchow
on Jan 1, 2011 at 11:09:51 pm
To make program or transport streams for broadcast. Not DVD.
