Updated Alexa Tool
Andreas Kiel
Updated Alexa Tool
on Nov 29, 2010 at 5:15:54 pm
Hi all,
For those 1 or 2 of you using the Alexa (or Alexa data) I've updated the Alexa Tool. It now allows copy of cards to a local disk in standard way and as a global usable ISO image.
There is a small help file included now.
Bad Alexa files will be mapped out now.
Also the XML handling is improved and fixes several of the Alexa XML stuff which are caused by some firmware versions of the Alexa.
The only thing which not improved is the price - it's still free.
As always use on you own risk. It's only tested with Alexa Prores files.
You can get it here alexaTool
Andreas
Spherico
http://www.spherico.com/filmtools
