making good quality DVD from animation
yuliya lanina
on Nov 28, 2010 at 2:30:50 pm
I have created animation in Flash which i then exported into Final Cut and added sound. The animation is based on paintings, is not vector based. I imported it into FC as Quicktime uncompressed file. It comes into FC as 1280x720 square pixel aspect, vid rate 10fps, data rate 95.0MB/sec. I originally made is at 29.97 fps. When i try to make DVD from it whether through Compressor or directly through DVD Studio pro (importing uncompressed Quicktime there), the quality of the picture downgrades beyond belief. Are there any suggestions on how to make DVD that would not downgrade the quality of the image so much. Thank you!
Rafael Amador
Re: making good quality DVD from animation
on Nov 28, 2010 at 4:51:58 pm
[yuliya lanina] " It comes into FC as 1280x720 square pixel aspect, vid rate 10fps, data rate 95.0MB/sec. I originally made is at 29.97 fps."
If the original movie is 29'97 fps, make the DVD from there.
rafael
http://www.nagavideo.com
Paul Jay
on Nov 29, 2010 at 12:24:51 am
Get the original 29.97 full quality movie.
Open in compressor.
Use DVD high quality.
Change framecontrols
Resize filter to BEST
Use files in DVD Studio Pro.
