Question regarding importing graphics in final cut pro
Vaishakh Babu
on Nov 24, 2010 at 2:22:52 pm
we all know that graphics have to be resized before importing into final cut, for eg:a 720*480 ntsc video the graphic has to be re sized at 720*540, am i right
but it seems that it applies for some resolutions only, correct me if i am wrong,
i have 2 images one at 720*480 and the other is 200*430, the 720*480 gets thinned out and the 200*430 one stays the same when imported into a ntsc 720*480 non-anamorphic sequence, why is this,
heres the link of the 2 images:
http://img254.imageshack.us/img254/7751/200430doesnotgetdistort.jpg
http://img338.imageshack.us/img338/6973/720480getsdistorted.jpg
also what does the "correct for apsect ratio" do when checked under the popup menu in the canvas and viewer window, and why is it greyed out sometimes ?
Sorry, but i am having a hard time understanding these concepts,
thankyou
regards,
Rafael Amador
Re: Question regarding importing graphics in final cut pro
on Nov 24, 2010 at 4:40:40 pm
[Vaishakh Babu] "we all know that graphics have to be resized before importing into final cut, for eg:a 720*480 ntsc video the graphic has to be re sized at 720*540, am i right"
Well, to match an NTSC 4x3 frame with square pixels (Photoshop), you need to make the graphic 720x540.
[Vaishakh Babu] "i have 2 images one at 720*480 and the other is 200*430, the 720*480 gets thinned out and the 200*430 one stays the same when imported into a ntsc 720*480 non-anamorphic sequence, why is this,"
Probably one of both pictures have wrong "pixels aspect ratio".
Have a look in he Browser and have a look to that setting. Change it and see what happens on the Viewer.
rafael
http://www.nagavideo.com
Vaishakh Babu
on Nov 25, 2010 at 2:56:58 am
Nope they both are square pixels, actually they are just portions of the same image, exported from photoshop
Rafael Amador
on Nov 25, 2010 at 6:35:45 pm
So if both shows as Square pixels on the Browser, left-click both stills on the time-line and "Remove Attributes> Basic Motion + Distort".
rafael
