Best Green Screen Solution
christina rule
on Nov 24, 2010 at 12:50:56 pm
Hey everyone,
I was debating if this was the correct forum for this post so I apologize if its not.
The company I am working for is looking to improve their green screen studio and I'm looking for any suggestions.
They are currently using green cloth, which has its obvious down falls, the biggest being the wrinkles. I've always worked with solid hard stages like painted wood etc. What would be best? This does not have to be portable.
If anyone could recommend any good resources and types of lights that would be appreciated.
A majority of the videos we do are full body, walks ons stuff like that. The current space we have is on the smaller side, however we have very high ceilings.
Thanks in advance!!
Rafael Amador
Re: Best Green Screen Solution
on Nov 24, 2010 at 1:16:43 pm
Hi Christina,
If I would have the resources, I would try this:
Michael Kammes
on Nov 24, 2010 at 2:29:32 pm
If you can test this first, do so.
Reflecmedia's solution will always put a small halo (what looks like a very slight shadow) around any of it's subjects. If the space is lit well, and there is good backlighting (and you can open up the iris a little bit) and you have a decent keyer you can get good results.
It's great for down and dirty setups, but the damn halo / shadow is really a pain.
Rent or test with it first!
.: michael kammes mpse
.: senior applications editor . post workflow consultant
.: audio specialist . act fcp . acsr
.: michael A T
Mark Raudonis
on Nov 25, 2010 at 5:05:28 pm
Another issue with "reflect media" is if your subject is wearing eyeglasses or has shiny jewelry on.
This "direct reflection" can result in "holes" in your keys where you may not want them. (Great for horror pix is you want a "man with no eyes" effect!)
Definitely test, test, test.
Craig Alan
on Nov 24, 2010 at 2:47:08 pm
Go to the lighting forum and do a search for “green screen”. You will find tons of info.
In general, you want to have ample space between the talent and screen and ample space between the talent and cam. Then you want to light the screen evenly and separately from talent. Kino flos work well on screen. There are stands and clips that allow you to stretch out fabric to help with wrinkles. An industrial quality hand steamer helps too. Painting with high quality green screen paint on flat surfaces works too.
You can also do a search on FCP forum for “green screen” or “pulling a key” or “chroma key.” Also try Google. This is a very popular subject. You might want to search for green screen studio design as well.
If you are thinking bigger budget try “green screen cyc” and see what’s out there. If you budget is big enough hire a studio designer.
OSX 10.5.7; MAC Book PRO (EARLY 2008); Camcorders: Sony Z7U, Canon HV30, Sony vx2000/PD170, Canon xl2; Pana, Sony, and Canon consumer cams; FCP certified; write professionally for a variety of media; teach video production in L.A.
Peter Mackay
on Nov 24, 2010 at 4:58:56 pm
The best green screen is made of spandex, never a wrinkle in sight. clip it to a frame and its perfect. We get them from Composite Systems in Los angeles and they are the inventor of Digital green and have the tech Oscar for it.
christina rule
on Nov 26, 2010 at 3:39:10 pm
Can you buy from them or just rent?
Peter Mackay
on Nov 26, 2010 at 4:51:49 pm
I believe you can buy from them, just give them a call.
© 2018 All Rights Reserved
