Making source time code visible
Leonard Frankford
on Nov 19, 2010 at 2:45:30 pm
I need to make a time code window dub for a client. In the old days of tape this was easy. How do I make the source time code visible on the timeline for output? Thanks.
Leonard F.
Shane Ross
Re: Making source time code visible
on Nov 19, 2010 at 3:20:50 pm
SOURCE...of the clips? Or the timecode from the timeline?
Here's a tutorial:
http://library.creativecow.net/ross_shane/visible-timecode/1
Shane
Leonard Frankford
on Nov 19, 2010 at 8:50:46 pm
The timecode of the source clips. Is there a way to drop them on the timeline and see the source clips timecode in the sequence window as the clips are playing?
Leonard F.
Shane Ross
on Nov 19, 2010 at 8:54:29 pm
[Leonard Frankford] " Is there a way to drop them on the timeline and see the source clips timecode in the sequence window as the clips are playing?"
Yes. Add the TIMECODE VIEWER filter on each clip (just highlight them all, then drag the filter to the clips, it will go to every one), and render the clips.
Shane
Leonard Frankford
on Nov 22, 2010 at 9:31:44 pm
Worked great. Thanks for the tip.
Leonard F.
