Fade to Black
Eddie Kesler
Fade to Black
on Nov 16, 2010 at 9:18:45 pm
How do you do a fade to black so that all layers at the end of a sequence goes solid black. Avid used to have a built in effect that you put on the top layer of video and all layers under it goes to solid black. I put a slug down and tried to do both fade out and cross dissolve, but the top layer that contains an alpha channel falls apart during the dissolve and shows through.
Any ideas? Should be simple.
Thanks. Eddie
http://www.jamedit.com
Evan Fitzer
Re: Fade to Black
on Nov 16, 2010 at 9:48:42 pm
I would just take a slug, put it on the top most layer, and then simply set the opacity to go from transparent to full black at what ever rate of time you wish. Instant master fade to black.
Evan Fitzer
Evan Fitzer
Kamloops, BC
Alan Okey
Re: Fade to Black
on Nov 16, 2010 at 11:43:56 pm
Nest the tracks and apply the fade to the nest.
Michael Gissing
Re: Fade to Black
on Nov 16, 2010 at 11:58:18 pm
[Alan Okey] "
Nest the tracks and apply the fade to the nest."
Be aware of the consequences of nests further down the post path, like handing over for grade and online. Those nests will have to be undone before sending to Color (for instance) or Media Managing.
Scott Sheriff
Re: Fade to Black
on Nov 17, 2010 at 2:06:40 am
I have to agree with Michael.
Nests, while a great concept, are a mixed blessing and can cause as many problems as they solve.
Scott Sheriff
Director
SST Digital Media
http://www.sstdigitalmedia.com
Tom Matthies
Re: Fade to Black
on Nov 17, 2010 at 11:41:59 pm
What Evan says...
Tom
Faster! Better! Cheaper!
Pick any two.
