Alternative to Log and Transfer???
Bob Flood
on Nov 16, 2010 at 8:31:21 pm
Hello Hello!
Been having some issues w log and transfer, like that it doesnt xfer a whole clip.
Is there an alternative 3rd party kinda thing? I am thinking i can use compressor, but i need to keep the TC.
thanx in advance
"I like video because its so fast!"
Bob Flood
Greer & Associates, Inc.
Shane Ross
Re: Alternative to Log and Transfer???
on Nov 16, 2010 at 8:39:06 pm
For what format? There are tons of options, but there are also TONS of tapeless formats..
Shane
Bob Flood
on Nov 16, 2010 at 10:19:28 pm
DUH!!!
We have been shooting with a Canon 5D.
The clips for this project are from the Canon 5D I have been using Log and Transfer to transcode to Pro Res, but Log and Transfer keeps quitting, or not completeing the import. I also would like to not have to tie up the editor transcoding clips
One thought was to simply run the clips through compressor, and add the tc later (i think there is some app to do that...havent researched too far yet.)
Sooooo, if there is another path to bring Canon 5D clips into FCP (as pro res or DVCPROHD or whatever) with the clips TC, I would like to try it. if not I will fudge together soemthing else
Bob Flood
Shane Ross
on Nov 16, 2010 at 10:28:38 pm
Magic Bullet Grinder. Does a good job. Doesn't bring in time of day code, nor add a reel number, but is fast. Each clip will start at 00;00:00:00.
Shane
Bob Flood
on Nov 16, 2010 at 11:56:13 pm
thanx shane!
Bob Flood
Bouke Vahl
on Nov 17, 2010 at 8:29:25 am
QTchange can insert the timecode, before or after the transcode.
http://www.videotoolshed.com/product/42/qtchange
(if you want to do it afterwards, do read the manual about file names and keeping the THM files!)
Bouke
smart tools for video pros
Michael Gissing
on Nov 16, 2010 at 10:30:05 pm
Bob, a common problem that has been reported here a few times is trying to edit or do other FCP tasks whilst L&T is running. I have had some incomplete file transfers because of this but now, I just batch convert with L&T and leave the computer alone. It is like Log & Capture in that sense. Just because it appears to be background doesn't mean you should continue editing.
Bob Flood
on Nov 16, 2010 at 11:57:54 pm
Micheal
Thanx for reply!
yeah, last night I was L and T a clip, I inadvertantly clicked on the timeline, and BAM the import stopped!
However, even when we leave the machine alone we get incomplete clips
nice.
Bob Flood
Michael Gissing
on Nov 17, 2010 at 12:00:36 am
Do you have other things happening in the background like emails polling or web browsers open and refreshing? Also have you done the usual maintenance (prefs, permissions etc). Once I learned to leave the L&T alone with nothig else happening on the computer, I have not had a single incomplete capture
