FCP Video Output
Mike Diaz
FCP Video Output
on Nov 16, 2010 at 2:52:34 pm
I have FCS 3 and my system is a Mac Pro late 2006. I would like to use my 52" Samsung LCD for the viewing output from FCP. I can connect it using a DVI to HDMI connector from the second video port on my card to my TV via HDMI. I get output as if it is a second monitor in OSX, but when I use FCP and try and output it doesnt display moving video, on the still shot when it is paused. Is this video card related or are my settings incorrect in FCP? Any help will be appreciated. Thank you all.
Tony Brittan
Re: FCP Video Output
on Nov 16, 2010 at 5:07:53 pm
You need an I/O card/device. I use MATROX MXO2.
Tony Brittan
Owner - Island Shore Productions
Mike Diaz
on Nov 16, 2010 at 5:32:31 pm
Sounds good. Too rich for my blood right now. I need lesser options. Thanks!
Mark Doyle
on Nov 16, 2010 at 5:11:48 pm
Mike
I may be able to do it at Mega Playground. Are you in NY
Mark
646-705-4289
Mega Playground
609 Greenwich St 8th fl
NY NY 10014
646-705-4289
Mike Diaz
on Nov 16, 2010 at 5:34:09 pm
Mark, you may be able to do what?
Mike
Job ter Burg
on Nov 16, 2010 at 7:11:25 pm
Probably a matter of DHCP compliance.
Mark Petereit
on Nov 16, 2010 at 7:19:56 pm
Keep your eyes open for a used BlackMagic HD Extreme board. I found one for < $200 on eBay and it works great!
Paul Jay
on Nov 16, 2010 at 11:07:41 pm
You should get a moving image this way through the cinema desktop preview in Final Cut Pro.
External Video set to ON?
What kind of timeline? What footage? What framerate? What Codec?
Jason Porthouse
on Nov 16, 2010 at 11:57:39 pm
Blackmagic Intensity is one of the cheapest options that will give you HDMI out (and in AFAIK) to drive your screen...
_________________________________
Before you criticise a man, walk a mile in his shoes.
Then when you do criticise him, you'll be a mile away. And have his shoes.
*the artist formally known as Jaymags*
Paul Jay
on Nov 27, 2010 at 9:41:10 pm
Video playback set to cinema desktop?
View-external video set to ALL Frames?
Should work. A better solution would be a Intensity Pro card.
