chroma key question
Kai Mariah
chroma key question
on Nov 16, 2010 at 2:15:48 pm
Hi.
I'm creating an animation in DAZ Studio on a green screen, rendering it to a .mov file, and then bringing it into Final Cut Pro (v6).
When I bring in the .mov file, for the most part the green screen is already removed (almost like it's transparent). The only think I need to do is clean up around the edges of the object or figure that I've brought in.
Normally what I do is:
video filters>key>color smoothing 4:1:1 and then video filters>key>spill suppressor-green and it removed the green edges completely.
However, I'm having trouble getting all the green removed on a character that has red hair and a red cloak.
If I click on the chroma key first it brings in the green background and then I can't get rid of it at all.
How do I get rid of the green edges completely on my character with red hair and a red cloak?
Thanks.
Kai Mariah
Dave LaRonde
Re: chroma key question
on Nov 16, 2010 at 4:05:02 pm
[Kai Mariah] "I'm creating an animation in DAZ Studio on a green screen, rendering it to a .mov file, and then bringing it into Final Cut Pro (v6)."
Do you not have the ability in this application to render to a quicktime codec that supports alpha channels, like ProRes 4444, PNG or Animation? Then you wouldn't have to resort to chroma key.
Dave LaRonde
Sr. Promotion Producer
Mark Suszko
on Nov 16, 2010 at 5:23:39 pm
We're really worried about creating a good matte, right? You cna use multiple iterations of the keyer, targeted tot he general background, and then to the edge area, that's one strategy. Another is to use the 3-way color corrector to really push the different levels around int he picture, and don;t worry that it makes the character look wrong-colored or anything. As long as it optimizes the matted area's level and contrast. Once you pull a good matte from that "ugly" color-corrected pass, use it on another track with the better-looking original, and maybe that solves your problem.
4:1:1 is bad to work in for chromakeying but you already know that. I would do this kind of work in Pro Res and then export the composited elements into whatever codec the rest of the project needs.
