Capturing VHS/SVHS to Final Cut Pro via other decks for TBC.
Chris Tomkins
on Nov 16, 2010 at 4:52:53 am
Hi all
First up, please let me assure you I have tried to find some answers here and on other forums - I understand this question gets asked a lot, but I have a twist on it.
I have several VHS/SVHS tapes I need to capture. They are of varying quality.
I have a pro SVHS deck with SVIDEO out, which I am running directly through my Panasonic camcorder to FCP - pictures come through fine and I can use capture now...
However, I am having a lot of trouble with the audio going out of sync when there is a dropout. I understand this causes timing problems and I need a Time Base Corrector.
The guy who own the edit suite I work in said I should run the video through their Digi Beta deck or DVCPRO 50 deck.
When I do this (via composite inputs) the DVCPRO 50 deck picture flashes green every few seconds, and the DigiBeta deck does a really slow "roll" creeping up a pixel at a time every few seconds.
Is there something else I should be doing here? Should I be trying to feed the TC-OUT from my SVHS deck to these other decks? Or the SVHS deck has a SYNC output - does that do anything?
Any suggestions?
Cheers
Chris
BJ Ahlen
Re: Capturing VHS/SVHS to Final Cut Pro via other decks for TBC.
on Nov 16, 2010 at 4:48:21 pm
I didn't think there were any SVHS decks without TBC, but then I recalled there were actually less expensive decks that cost a few hundred instead of the $1800 I paid for my AG-1830 SVHS deck back in 1998.
You did adjust the tracking, right? That sounds like it could be your first problem.
Find a post outfit that can do the transfer for you, shouldn't cost much.
Then you would get the TBC and a 4:2:2 transfer to say DVCPRO50 instead of the miserable 4:1:1 (DV25 I presume) through your camcorder.
A post house may also have a deck with better heads that can pick up poor tapes better.
Chris Tomkins
on Nov 18, 2010 at 1:40:33 am
Hi - thanks for replying. Yeah I'm adjusting the tracking - unfortunately these are family videos and there is about 200 hours of footage and I have no budget. I'm not wanting to edit them into anything, just to protect them from tape degradation over time.
