TWIXTOR 5 in FCP
Patrick de Teliga
TWIXTOR 5 in FCP
on Nov 16, 2010 at 4:04:58 am
I just installed the plugin twixtor pro 5, and I'm having some problems... (I have FCP 6.0.6)
When I change the speed in the filter tab, in the twixtor plugin itself, the size of the clip in the timeline doesn't change.
I.e: If I change the speed to 50%, the clip in the timeline does not double in size, it stays the same and I cannot drag the clip out to make it longer.
Similarly when I change the speed to 200% the clip does not shrink in size, half the clip is just black.
Does anyone know of this problem? Otherwise the effect looks great when rendered, but due to this problem, I can't use it.
HELP!!!
Pat
Jeremy Garchow
Re: TWIXTOR 5 in FCP
on Nov 16, 2010 at 5:26:55 am
You should read the manual, but in FCP it's tricky. For slowing down, you have to nest the clips in a new sequence to make up for the gain in duration as plug ins aren't allowed to change the duration of the clip in FCP.
or if you like pictures:
http://help.revisionfx.com/search/?h=53
Jeremy
Rafael Amador
on Nov 16, 2010 at 8:48:06 am
If you have spent a bunch of money buying the best retiming plugin for FC, spend a bit of time reading the manual.
rafael
http://www.nagavideo.com
Patrick de Teliga
on Nov 17, 2010 at 3:35:35 am
I'm sure you mean well, but thank you nonetheless for your condescension!
I am guilty of being lazy!
P
Patrick de Teliga
on Nov 17, 2010 at 3:32:54 am
Thanks mate!
P
Herb Sevush
on Nov 16, 2010 at 6:02:11 pm
Patrick -
You have to lay the clip you want to correct in the timeline in it's corrected size - the effect won't ripple the timeline for you.
For example - you have a 2" clip that you want to slow down by half - then put 4" of the clip in the timeline. You want to speed up the clip to twice as fast - then put a 1" clip in the timeline.
Herb Sevush
Zebra Productions
Patrick de Teliga
on Nov 17, 2010 at 3:25:02 am
Thanks mate, that seems to work well
P
Brandon Lee
on Feb 8, 2011 at 10:24:39 am
I am sure this will help:
