New Flash problem
Chris Baker
New Flash problem
on Nov 14, 2010 at 8:18:10 pm
Ok so the suggestion worked great with one problem. As soon as I changed the file extention the video would play but their is no sound yet the original file has sound.
Visit us at;
http://www.frogpondproductions.biz
(860)884-6015
The creative urge is the demon that will not accept anything second rate.
-Agnes DeMille
David Roth Weiss
Re: New Flash problem
on Nov 14, 2010 at 8:30:38 pm
What are you using to play this back with??? Use MPEG Streamclip or one of the Flash players if you're trying to use QT Player.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
http://www.drwfilms.com
A forum host of Creative COW's Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
Al Davis
on Nov 14, 2010 at 9:56:13 pm
Chris,
When you encode to H.264; you need to set the audio to AAC.
It defaults out of FCP to Linear PCM.
This is a common mistake, and easy to fix.
BTW - you technically don't even have to change the file to .flv; but perhaps your client will feel better if you do. Flash players easily read h.264(.mov).
All the best,
-Al
Al Davis
Visual Velocity
Brookline, MA
Chris Baker
on Nov 15, 2010 at 8:17:07 pm
Thanks all. I will change the audio and see how that works. I still find it odd that the original file plays fine then when you change the extention it won't play the audio in the Flash Player. Yet it I change the extention back it plays fine in Quicktime. Doesn't make sense to me.
Visit us at;
(860)884-6015
-Agnes DeMille
