Quicktime frame rate showing up wrong on a PC
Chris Ridenhour
on Nov 13, 2010 at 1:26:34 am
Hi, I'm a film composer. I recently got a HD Quicktime (exported from Final Cut Pro) to score too and am having a frame rate issue.
I have PC based system and the Quicktime plays back fine in standalone mode. But when I bring it into Cubase the frame rate is choppy. I did some investigating and found that it is because Cubase is seeing the Quicktime at 4 frames per second. When I open the Quicktime properties, sure enough, it's saying 4 frames per second (see pic ->http://img241.imageshack.us/img241/6601/framespsec.jpg
However, on a mac it properly shows 23.98 fps.
I tested the same file on a second PC and it shows 4fps as well.
David Roth Weiss
Re: Quicktime frame rate showing up wrong on a PC
on Nov 13, 2010 at 4:27:13 pm
Get the windows version of MPEG Streamclip (it's free) and export an identical file, but manually set the FPS properly.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
http://www.drwfilms.com
A forum host of Creative COW's Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
