Video player status bar
Brent Taylor
on Nov 12, 2010 at 8:06:00 pm
Been lurking for a few weeks and finally decided to join in.
I'm building videos for a client who wants a Youtube like status bar across the bottom, so viewers are visually aware of how much longer the video will play. I've mocked something up in Motion, but exporting it as .mov leaves black that has to be cropped/keyed, and using the .motn file takes forever to render.
Anyone know of any plugins that look like what I'm trying to create?
Shane Ross
Re: Video player status bar
on Nov 12, 2010 at 10:48:16 pm
How will viewers be watching this? On the web? There is a status bar that goes across QT files when you play them. Not RED like YouTube, but it goes.
Shane
Brent Taylor
on Nov 17, 2010 at 2:00:57 pm
It will be viewed in a break room on a tv. Whatever media player they are using does not have the status bar popup on the bottom. I've worked something out for it using Motion, but it isn't as "drag and drop" as I'd like - since Motion requires that you set up the length of the project when you create a new project, I have to open the "template" that I made, copy all the elements, open a new project with the set time that I'd like, then add in all the other stuff.
