Changing Frame Rate and Speed
Alan Thompson
on Nov 11, 2010 at 4:13:37 pm
I am currently working on a project in which most of the footage was shot natively in slow motion, probably 60 fps, with 16mm film. I was wondering if there was some rule of thumb by which you could change the speed of the film in FCP and make the playback fairly smooth?
I have tried various speeds, but nothing seems to work. When it plays back now it is jumpy and doesn't necessarily flow very well. Thanks in advance!
Dave LaRonde
Re: Changing Frame Rate and Speed
on Nov 11, 2010 at 6:53:07 pm
Since we don't know the frame fate of the footage in question -- neither the frame rate at which it was shot, nor the frame rate of the footage in your FCP browser -- it's pretty tough to give a useful answer.
Please say you already removed the 3:2 pulldown from it if it was originally 29.97.
It sounds like you'd need to engage in a lot of experimentation to get it right.
Dave LaRonde
Sr. Promotion Producer
