Conform frame rate without Cinema Tools?
Clara Rolls
on Nov 11, 2010 at 1:04:57 pm
I have some videos captured from an NTSC dvd that I changed to 25fps via Compressor. Quicktime says it's 25fps but Final Cut 6 is reading it as 29.97 still. For some reason I don't have Cinema Tools, probably opted out of installing because I've never used it :(
CT could fix it so easily but I'm in need of an alternative solution...advice or directions to the right thread much appreciated.
Cheers :)
Walter Soyka
Re: Conform frame rate without Cinema Tools?
on Nov 11, 2010 at 4:48:58 pm
[Clara Rolls] "I have some videos captured from an NTSC dvd that I changed to 25fps via Compressor. Quicktime says it's 25fps but Final Cut 6 is reading it as 29.97 still."
That's really bizarre -- are you sure Quicktime and FCP are looking at the same files?
[Clara Rolls] "For some reason I don't have Cinema Tools, probably opted out of installing because I've never used it :( CT could fix it so easily but I'm in need of an alternative solution...advice or directions to the right thread much appreciated."
I didn't realize that Cinema Tools was an optional install. Why not re-run the FCS installer from the original discs and de-select everything but Cinema Tools?
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Clara Rolls
on Nov 11, 2010 at 9:50:30 pm
Thanks for the response Walter :)
It's definitely the same file, I've triple checked that and tried taking them out of FCP, restarting, putting them back in etc. I read that it's a common problem when a video is changed from ntsc to pal that FCP misinterprets the metadata.
I'm afraid I don't have the installation discs - it was a volume licence from my last job. But if there's no other solution, I guess I'll have to find me some discs!
