Bad Quality export :(
Senem Ocal
on Nov 11, 2010 at 9:09:39 am
Hi everyone...
i finish my editing with final cut pro 7. i saw good quality when playing on timeline. But when i stopped playing the quality getting bad at the freeze frame.
And i cant get qood quality export. I saw the film as freeze frame quality...
Do you have any suggestions?
Zak Ray
Re: Bad Quality export :(
on Nov 11, 2010 at 8:06:40 pm
What format of footage are you working with? What do you mean "it got bad"?
Nicolas Servide
on Nov 21, 2010 at 3:28:40 pm
I get a very similar problem.
The video in the timeline looks fine, but when exporting using ANY METHOD, the image looks jagged.
Also, I cannot export a QT reference. Even it "make movie self-content" is uncheked, the result is the same.
Any thought?
Zak Ray
on Nov 21, 2010 at 10:28:31 pm
Again, what kind of footage are you working with, and what are your sequence settings?
Nicolas Servide
on Nov 22, 2010 at 10:18:23 am
I am working with video shot with the codec DVCPRO HD 720p50
You can see the timeline settings in the image.
I have tried to export using "QuickTime conversion" and also via Compressor with really bad results.
Actually if I create some text, the letters would look bad as soon as I render the sequence.
Ps. Also, I cannot create a QT reference (even when "make movie self-content is unchecked). Is it a known Final Cut bug or is it just me?
Zak Ray
on Nov 22, 2010 at 7:49:23 pm
If you haven't rendered your sequence beforehand, this can prevent FCP from creating a reference file (because it has nothing to reference).
I see no image attached.
Nicolas Servide
on Nov 22, 2010 at 7:54:27 pm
Hi Zak,
Thanks for your reply.
I will try rendering the sequence first.
These are my setting:
Any idea about the jagged text?
Nicolas Servide
on Nov 22, 2010 at 7:56:17 pm
Oh, I forgot,
I have also tried setting the dominance field to "none"
with no better results...
Zak Ray
on Nov 22, 2010 at 7:58:15 pm
Not sure why your text is coming out poorly (are you viewing it at 100% or using a broadcast monitor?).
As for the export itself, I'd recommend using QT Movie (not QT Conversion) to get a self-contained file at full quality. Then bring that to Compressor for further compression.
Nicolas Servide
on Nov 22, 2010 at 8:18:04 pm
Thanks for the exporting tip.
I am viewing the video at 100% in my iMac.
I just find a way around it, sending the video to MOTION and adding the text there. But it must be a way of doing this in FCP, right?
Zak Ray
on Nov 22, 2010 at 8:37:18 pm
Can you send a screenshot?
Nicolas Servide
on Nov 22, 2010 at 8:50:22 pm
here is a QT movie export (direct from the timeline - no convertion)
Zak Ray
on Nov 23, 2010 at 11:40:39 am
Well that's dodgy... try changing the sequence to ProRes.
